71 Door Pulls - NCRS Discussion Boards
71 Door Pulls
  • Frank B.
    • April 30, 2002
    • 66
    71 Door Pulls
    Where the Door Pulls Originally Black and Dyed to the interior color or where they moulded in colors?
  • Mike E.
    • February 28, 1975
    • 5153
    Re: 71 Door Pulls
    I'm almost positive they were molded with the color throughout.
    • Don L.
      • August 31, 2005
      • 1006
      Re: 71 Door Pulls
      Interesting question. The answer could be either, depending on the situation. Having worked in the OEM interiors business for many years, I've seen intances where; in the case of stock outs, rework, etc, a color dye was sprayed to suit the need. For example, if a black part was was out of stock, a tan part was sprayed with a special color dye (I've since forgotten the brand) to meet the need. The problem with that was that the color, of course was not through the part, and any scratches would show through. As a consumer, I was disappointed with this, when I had a GM car that I ordered/bought new. Six months or so after the purchase, I noticed that my tan ash tray door had black scratches in it. Upon closer examination, I found that the door was actually molded in black, then painted tan to suit. I think this practice was also used for service, so that each color didn't have to be stocked. Hope this helps.
      Don Lowe
      NCRS #44382
      Carolinas Chapter
      • Dennis D.
        • March 1, 2000
        • 1071
        Re: 71 Door Pulls
        Your right. With the hard plastic for sure. My kick panels were painted. As are my rear convert quarters. But the frame for the rear compartments was solid colored plastic. (found that out when I broke it)
        Now for the point that gets alot of opinions. You called the color dye, and that it was not colored through the part. Wouldn't that make it a paint?
        • Don L.
          • August 31, 2005
          • 1006
          Re: 71 Door Pulls
          Oh boy. Not sure who you mean, Dennis, when you say "you called the color dye." I agree with the conflict over dye vs paint, however, I just used the term dye to be consistent with Frank's query. You caught me trying to fly under radar.
          To me it's paint, because it is limited to the surface. I think dye indicates further penetration, however, Mr. Webster defines "dye" as "soluable or insoluable coloring matter". Either way, the color-over process was inferior but unfortuantely common, IMHO.
          Let the debate begin...
          Don Lowe
          NCRS #44382
          Carolinas Chapter
          • Dennis D.
            • March 1, 2000
            • 1071
            Re: 71 Door Pulls
            Good answer.
