1966 Master Cylinder Replacement - NCRS Discussion Boards
  • David J.
    • August 19, 2007
    • 65
    As I install new brakes on my '66, i am faced with the decision of what to do with the master cylinder. It must be replaced and, while talking with several friends, have generally been advised to go with a dual master cylinder conversion kit. While I want to keep my car as original as possible, I understand the logic in their argument. However, the thought of changing the single feed master cylinder from the factory doesn't sit well with me. I would appreciate hearing the thoughts and wisdom of those who have been in the same situation or have some experience regarding the dual master cylinder system conversion kit.
    Dave
    • 43247
    Re: 1966 Master Cylinder Replacement
    Dave
    Dave-----
    There's no question that a dual master cylinder system provides more safety than a single master cylinder. However, that doesn't mean that single master cylinder system is unsafe. If it were me, I don't think I'd make this conversion. I'd just make sure that my braking system was in good condition "all the way around". Also, make sure that your parking/EMERGENCY brake system is in good working to give you SOME stopping power just in case things do go wrong.
    • Peter J.
      • September 30, 1994
      • 586
      David,
      I am switching to power brakes on my 66 so I could have a dual master cylinder. I went the correct parts route and it has taken several years to find an original booster (part number and date) and master cylinder. I got it from a friend but it turned out to be a 65, but Jill at Dr Vette swaped for a 66 when she rebuilt it.
      I never had a problem with stopping due to my original MC, in fact the car stopped pretty good And if you have ever been on a road tour with Jimmy Gregg and the Carolina's chapter that is saying something.
      I think joe gave good advice - There are a lot of non power brake mid-year and solid axle cars out there on the road with a single MC
