correct C1 clutch return spring bracket bolts - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1133
    Paragon carries a set of clutch return spring bracket bolts with "E" headmarks for $5 dollars. These are 3/8-24 x 3/4, zinc bolts, Paragon no. 362K. They also carry a bolt called "clutch bolt" with the same dimensions with a "C" headmark and note to ask a qualified judge about its application, Paragon no. 362. They charge $8 dollars per bolt for this one, so that would be $16 dollars for a pair. What is the proper application here, especially regarding a 59?
    Paragon has a number of bolts like that on thir site, where they don't really tell you what they're for...
