Cold Climate Power Steering Fluid - NCRS Discussion Boards
  • Jim S.
    • August 31, 2001
    • 730
    Is this part number (12345866) for a case of cold climate power steering fluid?
    I believe that one container (32 fl oz) is 12345867.
    Jim
    • 43247
    Re: Cold Climate Power Steering Fluid
    Jim
    Jim-----
    There are no part numbers that I know of for case quantities of a GM item. However, certain part numbers may only be supplied from GM in a case or other unit quantity greater than "1".
    In this situation, the GM #12345866 is a pint size container of the cold climate power steering fluid. GM #12345867 is a quart size container. Both are supplied from GMSPO only in case quantities of 12. Many dealers may stock these, though, so you can purchase from them whatever quantity you'd like.
