4656 Reproduction Fuel Pump - NCRS Discussion Boards
  • Dennis C.
    • June 30, 2002
    • 884
    Hi All,
    I hope everyone had a great holiday!
    I just received a reproduction 4656 fuel pump from Zip Products for my '61. The diaphragm extends about a 1/4" past the housing all around.
    Is this the way it should be? Should it be trimmed?
    Thanks in advance.
    Dennis
  • Mike E.
    • February 28, 1975
    • 5139
    Re: 4656 Reproduction Fuel Pump
    1/4" extension is correct. That's how, on an original, you can see the wavy lines and know that it is still an original diaphragm.
    • Dennis C.
      • June 30, 2002
      • 884
      Thanks Mike.
      It looked strange, but I am glad it's right.
      Dennis
      • Roy B.
        • February 1, 1975
        • 7044
        Should my NOS 55 be a 1/4 because it's not
        • Mike E.
          • February 28, 1975
          • 5139
          Totally different bottom. Yours is one bolt with a stamped lower cover, 4656 is two screws with a cast lower cover. Apples and oranges.
          • Roy B.
            • February 1, 1975
            • 7044
            Thanks Mike
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12762
              these pictures could be nice examples to compare...
              regards,
              Rob.
              Rob.
              NCRS Software Developer
              • Dennis C.
                • June 30, 2002
                • 884
                Great!
                Thanks.
                Dennis
                • Ian G.
                  • September 3, 2007
                  • 1114
                  I have a rebuilt original 4656 pump, and the rivet is steel, rather than copper. I know from some other threads the judges sometimes look for a copper rivet. Is it worth it to switch the rivet, or would the rivet be prone to failure from work hardening? or am I over thinking it?
                  • John D.
                    • December 1, 1979
                    • 5507
                    NOS 4657 pump has the diaphragm sticking out about 1/4" also.
                      Ian -
                      Rest assured that the rivet is NOT copper - it's copper-plated steel. If it was copper, it'd last about two minutes.
                      • Ian G.
                        • September 3, 2007
                        • 1114
                        That's what I thought. I was like "Is this GM or Ancient Egypt?" :P
                        • Loren S.
                          • November 1, 2002
                          • 172
