65-66 non-power brake master cylinder; repro vs. original - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7024
    Can anyone tell me if the current repro non-power brake master cylinder for '65-'66 is detectably different from original or NOS examples?
    Gary
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65-66 non-power brake master cylinder; repro vs. original
    Originally posted by Gary Beaupre (28818)
    Can anyone tell me if the current repro non-power brake master cylinder for '65-'66 is detectably different from original or NOS examples? Gary
    Gary -- can't answer your question, but as I see it's been 7 hours and no one else has responded, can I put a related question to you ?
    I have two '65's. To my chagrin, I discovered about 10 years ago, when reading my '65 TIM&JG that one of my two was not factory correct (see attached thumbnail, taken with mirror, then flipped digitally so the cast number 618967 reads correctly).
    Other car has the casting # 2225032 in same location, and is correct per TIM&JG.
    My question: is the 618967 an early service unit (prior to 1980 when I bought the car) ? I haven't compared both side by side, but they appear identical otherwise.
    • William C.
      • May 31, 1975
      • 6037
      I believe the originals have a casting date on the bottom of the casting should a judge decide to use a mirror in that area.
      Bill Clupper #618
      • Gary B.
        • February 1, 1997
        • 7024
        Aftermarket/Generic vs. repro vs. NOS vs. original
        Wayne,
        It turns out I must have 3 master cylinders; one almost certainly an aftermarket or generic (on the car) that does not have the correct casting number on the bottom; one repro (that I temporarily can't locate in my badly organized inventory) that from memory has the correct casting number on the bottom; and one NOS that I know has the correct casting number on the bottom and what looks like "R6", which may or may not be a date code.
        Gary
        • Gary B.
          • February 1, 1997
          • 7024
          Date code?
          Wayne,
          The other embossed info on my NOS cylinder looks like a "145" that appears on the underside where one of the bails (sp?) sits. Maybe this means the 145th day of the year?
          Gary
          • Rob M.
            • April 30, 2003
            • 657
            HI Gary,
            I replaced the MC on my '66 with a reproduction a couple of years ago. I don't remember the reproduction MC having the Julian date on it. It did have the correct casting number however and did pass judging. The MC that I took off the car and have kept does have a Julian date on it (I don't remember the number off the top of my head). Hope this helps.
            Rob
            Rob
            '66 327/300 Regional Top Flt
            '08 6 speed coupe
            • Gary B.
              • February 1, 1997
              • 7024
              Julian date
              Rob,
              So the 145 under the bail on my NOS example is the 145th day of some year?
              Gary
              • Wayne M.
                • March 1, 1980
                • 6414
                Re: Julian date
                Rob,
                Gary
                I would say so. Here's some further info from my two.
                The Julian dates are on the outboard bail indent; on the one I show in the pic above (with the non-approved cast #) has '183'. The date on my other is '050'. IMO, that symbol is a 'flying' "P" superimposed over a second character. Perhaps it is a Bendix trademark. I know there has been RESTORER articles on this stuff. but can't locate. The "R" and a single digit that follows is probably the mold #.
                The '65-8 P&A30 Gr 4.650 shows the '65-6 master cyl as GM # 3866446, with descriptive (Bendix 618690...).
                • Rob M.
                  • April 30, 2003
                  • 657
                  Gary,
                  I can't promise that to be the case, however that is what I learned from other members when I was researching master cylinders a couple of years ago. Someone with more expertise might verify for us. What I do know is that the MC that came off the car (and I have no reason to believe it wasn't original) had 3 stampings on it - the casting number, a letter/number combo (like R6 or R5) and what I believe is a julian date. I think the julian date on mine was in the high 200's. I don't have access to it right now, so I can't be certain.
                  I would be happy to email you a picture of mine when I get home from our holiday vacation. Let me know.
                  Rob
                  Rob
                  '08 6 speed coupe
                  • Gary B.
                    • February 1, 1997
                    • 7024
                    Rob,
                    I don't think a photo is needed, but thanks for the offer. My NOS example sounds like it will work perfectly for me based on the 145 julian date for my July car.
                    Gary
                    • Bob J.
                      • December 1, 1977
                      • 714
                      Re: Julian date
                      If the "D" on later master cylinders is the Danville.IL. foundry does anybody know which foundry the "R" represents? Bob
                      • Gary B.
                        • February 1, 1997
                        • 7024
                        D for Danville; R for ???
                        Bob,
                        I couldn't find anything in the archives on the R letter.
                        Gary
                        • Peter J.
                          • September 30, 1994
                          • 586
                          Gary,
                          I have a 149 for a late june car, so I think you are right 145 should work for a july build car.
