Test Harness - NCRS Discussion Boards
Test Harness
  • Michael B.
    • April 1, 1999
    • 178
    Test Harness
    Afternoon Folks,
    Within the next 5-10 days I want to fire up the engine, as a test run before I put the body on. Has anyone ever built a basic electrical harness for the starter, ignition, alternator, for a test run of a new engine on rolling chassis. The concept is obviously simple but I'd hate to forget something obvious.
    As to other factors I'm thinking the basic caveats are:
    1. temp sensor
    2. oil sensor
    3. momentary switch for the starter
    4. transmission in neutral/park
    5. maybe raise rear wheel / chock front wheels f&b
    oh yes, fire extinguisher !
    garage will be open
    Thanks for the input.
    Michael B.
  • Bob S.
    • August 12, 2007
    • 185
    Re: Test Harness
    Michael,
    The Summer '98 Restorer has an article "An Engine Test Dashboard Box" by Bill Sangrey that gives the whole setup. I was just reading it last week off the new edition Corvette Restorer CD. I have the C1 58 - 60 version but I think they all have the old Restorer issues. The best $40 I ever spent.
    Sully
    • Michael B.
      • April 1, 1999
      • 178
      Re: Test Harness
      Bob,
      This is a great starting point. In fact I have the C3 CD (I bought the first edition) and the article was there. This never popped up in my search though.
      A few changes need to happen of course. The oil sender is electric. I don't think there is a ballast resister in this ignition - if it is it's in the distributor, but I don't remember it.
      I'll draw out the diagram and take some pictures to update this to a C3 test dashboard box.
      Thanks a lot.
      Michael B.
      • Jim T.
        • March 1, 1993
        • 5351
        Re: Test Harness
        Michael the last Corvette to use a ballast resistor was 1967. The 68-74 point equipped Corvettes used a resistor wire from the fuse block to the coil.
