C3 on jack stands question - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    I was told that it was a good idea to release the hood and door latches when putting the car on a lift or on jack stands. This was because the cars "flex" when raising them resulting in unnecesary stress on the fiberglass.
    My car is a '72 big block and flexing is easily visible due to the extra weight.
    Is there a way to support the front end after it has been put up to prevent this?
  • Tom H.
    • December 1, 1993
    • 3440
    Re: C3 on jack stands question
    Just put an extra set of stands under the front, near the sway bar area. How long will the car be supported on stands.
    Not a bad idea to crack the doors.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Tom L.
      • October 17, 2006
      • 1439
      I am aware of the idea of jack stands in the front. My concern is will I be putting too much stress on the front if they are a little higher than they need to be. One of my thoughs was to simply put a bottle jack under the cross member, but how much should I lift?
      During the winter months I like to leave it up for as lonag as a project lasts. Could be weeks.
        • 15610
        Using a jack or jack stand on the front cross member without something to spread the weight will result in the often-seen dents in the front cross member. Use caution to prevent these dents -- they are far easier to prevent than to remove.
        • Erv M.
          • February 21, 2007
          • 445
          When using a small scissor lift do you have the same sagging concerns?
