63 parking brake question - NCRS Discussion Boards
  • Mike G.
    • April 30, 1997
    • 14
    I am in the process of restoring a 63 SWC and just recently noticed that the parking brake hand lever is from a 64. The car was built July 1, 1963 so I thought it may have a 64 unit because it is a fairly late 63. All of the cables and brackets on the frame were 63. The parking brake dash assembly had the pully wheel on the firewall. I believe someone has changed it in the past, since there was no upper cable attached when I removed it. Would you agree with this or are there some 63's out there with 64 assemblys....Thanks Mike
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 63 parking brake question
    I am not aware of 64 units being present on 63's. Not to say it didn't happen, but not as far as I know. Hopefully someone smarter than me can confirm.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Stuart F.
      • August 31, 1996
      • 4676
      The only thing I can report is that my July 9 build is all 63.
      Stu Fox
      • Steven S.
        • November 1, 1995
        • 151
        Interesting question. My '63 was built during the first week of July and has '64 hand brake as well. Not sure if it really came that way or not. I have looked at other '63's and find none that have '64 hand brake, but have never found one built the same week as mine.
        • Alan D.
          • January 1, 2005
          • 2032
          The 64 AIM has handle listed as pn 3842932, sec 5 sheet C1.00, with a release date of 6/5/63.
          What does your 63AIM sheet show for dates and changes?
          It would appear that after 6/5/63 the newer handle (64) could have existed.
          Somebody may know more about the pn - if it existed in June 63
          • Mike G.
            • April 30, 1997
            • 14
            Hi Steven, Does your parking brake actually work? Do you know if it has the 63 cables going to the rear brakes? On the 63 I am restoring, everything is pure 63 from the firewall back. I don't know how the cable would hook up to the handle. Thanks..Mike
            • Steven S.
              • November 1, 1995
              • 151
              Mine is '64 all the way back. I have checked the frame for any indication of a '63 but have found none.
              • Chuck G.
                • May 31, 1982
                • 2030
                Stu Fox
                My July 63 built 63 is all 63 also, and I've owned the car for 41 years.
                Chuck
                • Tom H.
                  • December 1, 1993
                  • 3440
                  This might get interesting. Might learn something if we stick around.
                  Tom Hendricks
