engine casting date - NCRS Discussion Boards
engine casting date
  • Jeremy H.
    • January 1, 1999
    • 260
    engine casting date
    What is the closest casting date anyone has seen, for an original car, in relation to the body build date? Is a week or less to close?
    Jeremy Hedges
    • 15616
    Re: engine casting date
    Do you want to tell us what year Corvette, it is Corvette, right; you are concerned with.
      • 3416
      Hi Jeremy,
      Here's the info from my 71, 350/270, 4-speed.
      The block was cast on December 31st, twilight shift.
      The engine was assembled on January 7th.
      The trim tag indicates assembly January 14th.
      I guess this is pretty typical, so it might help you determine what a really quick 'cast/ assembly period' may be.
      Merry Christmas!
      PS: The vast majority of parts with dates are right where I'd think they would be for this 'common' drive train... except for the intake manifold and one exhaust manifold which have August dates.
      • Rick S.
        • January 1, 2003
        • 1203
        Here is the info on my 67 L-79
        Engine casting date of 5-31-67 with stamp pad date of 6-5-67.
        Body build date of 6-16-67.
        Estimated car birthday of 6-19-67/
        Rick
        • Mike M.
          • May 31, 1974
          • 8400
          all #'s appropriate.mike
          • Jeremy H.
            • January 1, 1999
            • 260
            1966 Corvette, casting date is 1-10-66, assembley date of 1-13-66, body build 1-14-66 and a birthday of 1-17-66.
            • Warren S.
              • April 30, 1987
              • 100
              Here is the info on my 67. I've seen closer and some a lot farther and dates more scattered dates.
              Body build Dec. 6, 1966
              Block cast Nov. 30, 1966
              Heads cast Nov29, 1966
              Engine assembly Dec.1, 1966
              Car assembly Dec. 7, 1966
              Car shipped by rail Dec. 9, 1966
              Car arrived at dealer Dec. 12, 1966
              1st owner took possession Dec. 14, 1966
              Warren
