C1 rear leaf springs - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    I've cleaned up the original leaf springs on my 61. All the part numbers are correct . I noticed that both base springs( the longest ones that bolt to the mounting points have a small "R" cast in them in the center rib area. Is this just a casting ID mark or are there left and right designations on factory springs?
  • Mike E.
    • February 28, 1975
    • 5153
    Re: C1 rear leaf springs
    Just a casting mark---have never seen an "L". Springs are interchangeable right to left, as you know, and not oriented left/right by the factory.
