Re: Muncie Transmissions, Close vs Wide ratio question
Me too! I drive mine with the transmission a lot - up and down shifting. I use the brakes only for a complete stop or hold on a hill, so to speak. With down shifting, I just hold my foot steady on the gas and drop it in the next lower gear w/o any perceptible engine speed change when I release the clutch. Nice and smooth. With my son's 78 p.c. w/ W.R., it is more difficult to do w/o engine speed up. I don't know if I explained that well, but when you hold your foot steady, obviously, the engine will speed up when you push the clutch in, and when you drop it in the next lower gear and let the clutch out the engine speed is perfectly matched to the speed of the car. Then you back off for engine braking. Even my restrictive exhaust system sounds pretty good, but I am tempted to slip on the set of Cherry Bomb muflers that I have in the garage and return to my youth, remembering the days of "window rattling". (I once was in a street race where I went through a measured quarter, then immediately started down shifting in anticipation of a R.R. crossing. The guys at the end of qtr. said their car windows rattled like crazy, like a shock wave! That was w/my 56 w/58 Fuelie engine and glasspacks).
Stu Fox
Stu Fox
