Re: Kennedy pattern - Knoch Tops??
Jerry,
The original top shows another feature that the "repop" does not have correct. The front wind lace has a tapered cut on the ends of the rubber bead that the sewn seam follows. The "repop" is straight, non tapered which does not allow a smooth correctly fitting wind lace at the corners. True, one can rip the seam, modify the rubber and restitch the seam correctly. But I should be correct out of the box.
Again I ask if anybody has photos of a replacement top that fits correctly?
Jerry,
