ACCORDING TO NCRS
70-72, 4TH EDITION TECH. INFO. MANUAL + JUDGING GUIDE, THE FIRST AND SECOND DESIGN EXAUST TIPS WERE SIMILAR, OTHER THAN BOTTOM WELDED SEAM FOR 2ND DESIGN AND SMOOTH BOTTOM WITHOUT A SEAM ON 1ST DESIGN. DOES ANY MEMBER OR JUDGE KNOW HOW PIPE IS FASTENED TO FLAT RECTANGTULAR BACK OF TIP?
WOULD BACK BE CRIMPED AND SPOT WELDED OR CRIMPED AND A FULL BEAD AROUND PIPE OR SOMETHING ELSE?
) the seam is visible if one looks at the right angle. That is easier done when the tip is off the car.
