'63 Conv Antenna Cable Routing - NCRS Discussion Boards
  • Jack Y.
    • June 30, 2005
    • 76
    I checked the AIM but didn't see if the antenna cable for a conv was routed in-board or out-board of the deck-lid spring. Logic would seem to favor out-board but mine was the opposite. The rear electrical feed was out-board. Who knows if it was the original location, not me. Thanks!
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: '63 Conv Antenna Cable Routing
    Jack;
    I'll check mine later today and, if no one else has provided you with an answer, I'll post the results of looking at mine which is an original July build. Got to go see more Docs now.
    Stu Fox
    • Joseph S.
      National Judging Chairman
      • March 1, 1985
      • 868
      Both the wire harness and antenna cable typicaly run outside of the spring. That is the most direct route and keeps them away from being caught up in the spring.
      I hope this helps. Joe
      • Jack Y.
        • June 30, 2005
        • 76
        Thank you, that is what I guessed. Mine actually was hung up in the coils of the spring so I supposed it had been replaced. The harness was correct so I will correct the anternna cable. Thanks again! Jack
