66' Alternator pulley diameter - NCRS Discussion Boards
  • Gary N.
    • August 31, 1986
    • 118
    I have a 66' 327ci, 350 hp, AC coupe. I bought a reproduction replacement belt for the alternater from Quanta. When I adjust the tension,the alternator goes out almost to the end of the adjustment groove. This is the second belt that I got from them that was like this. I know that on some of the other midyears that the higher horespower cars had larger pulleys to slow down the rpm of the alternator. Can anyone with a 66' 350hp tell me the correct diameter for the alternator pulley.
    Gary Nyland
    1966 Black Corvette Air Coupe
    2014 Black Z-51, 3LT Coupe
    1955 Black Chevy Belair Gasser
    1955 Nomad
    • 43247
    Re: 66' Alternator pulley diameter
    Gary-----
    GM says that the pulley used for your application was GM #3864180 and GM says that pulley had an OD of 3-3/64".
    • Wayne M.
      • March 1, 1980
      • 6414
      I have a 66' 327ci, 350 hp, AC coupe. I bought a reproduction replacement belt for the alternater from Quanta. When I adjust the tension,the alternator goes out almost to the end of the adjustment groove......
      Gary -- in addition to what Joe L. has said, the alternator / water pump / crank belt is # 3847702 (3/8" x 52_1/2") with '66 Corvette w C.A.C. w/Sp. H/Per., 327 except P/S.
