1963 L75 AFB vacuum fittings w/AC, PB, AT - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11366
    Our swc with 327/300(L75) with Powerglide(M35), Power brakes(J50), & "ugly" Aftermarket AC...... I have some fittings to connect the AC vac source which was plugged into the aftermarket AFB I removed. Now have a nice Carter 3460S rebuilt on there which will have all the right linkage, fittings etc.
    Pic#1 is what was on the old AFB, w/PB and the PCV valve going to the rear as original.
    Pic#2 is what I bought, allegedly for 63/64 w/AC & Powerglide
    Pic#3 is what I think it should be
    Pic#4 is a slight rearrangement of #3 on the 3460S AFB.
    The AIM is unclear, and Noland has some good photos of L75's, but not with the same intake as this one which is a correct 3799349-dated K122. Noland's page 217 shows a 64 with the above options, but has a separate threaded hole in the intake(#3844459?) for additional fittings.
    ?'s
    -Does Pic#4 look possible for the application? It looks like a mess to me.
    -Did AC + AT + PB cars use a different intake, with the separate threaded pipe thread hole for additional fittings?
    Rich
  • Mike M.
    • May 31, 1974
    • 8408
    Re: 1963 L75 AFB vacuum fittings w/AC, PB, AT
    my 65 365hp c-60 coupe doesn't have fitting such as you pictured but i believe the 63s differed in this respect. did you look in the Long Island corvette supply catralog. seem to remember they have the pieces. good luck, mike
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11366
      Thanks Mike, good idea........Yes they have it online in the PCV section, Pt#22-13M.
      It looks alot better than what I thought it was.
      Rich
