Painting new rear spring - NCRS Discussion Boards
  • Michael G.
    • March 2, 2008
    • 487
    I am using the Seymore grey primer (said to be correct color) to paint my new rear spring and would like to have good coverage. I worry about the possibility of cracking once subjected to the flexing of normal use. I don't believe there is any flex agent in this paint and wonder if anyone has had a problem when 2-3 coats of this paint is applied to a driver car. Thanks, Mike
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Painting new rear spring
    primer will not hold up if it is in damp weather. color should not flake if you glass bead surface first. recommend you coat with a satin clear or use a battleship grey or a finish paint that seals. primer does not seal unless it is an epoxy two part mix.
    • Michael G.
      • March 2, 2008
      • 487
      Thanks Gene. Good points. Appreciate your input. Mike
      • Thomas H.
        • August 31, 2005
        • 1068
        Michael,
        I used the spring paint from Quanta and it worked very well. It has been three years since I did it and it looks just fine. 1 can was more then enough to do the spring.
        Tom
        2007 Z06, Lemans Blue
        • Michael G.
          • March 2, 2008
          • 487
          Thanks Tom,
          I am a little concerned about the coating I have and will get the Quanta product instead. Best wishes, Mike
          • Timothy B.
            • April 30, 1983
            • 5202
            Michael,
            If you install new liners from a kit and use a new center bolt make sure you grind that center bolts head down to match the old bolt head. If installed and torqued with a tall head you will NOT be a happy camper.
            • Michael G.
              • March 2, 2008
              • 487
              Thanks for the "heads-up" Tim. I could have walked right into that one. Good lookin' out. I appreciate it. Mike
