I just bought an AC Delco '66-'67 temp gauge. It's a GM Restoration part #6402594. Inside there is a note saying that "this gauge is precision wound to original Delco specs and is extremely accurate. If your new gauge does not read correctly, then you may have to replace the engine sender unit with the correct delco part. Your Dealer who sells these gauge has the correct part in stock".
So I had one of those repro sending units that was correctly calibrated for my original gauge and it worked like a charm. However I installed the new gauge and it reads too low, barely over 100 degrees where it should read 180. So I go to Napa Auto parts store and buy the plain jane sender for a '67 SB. Same thing, it reads to low.
So I go back to the Vendor who sold me the gauge and bought the AC Delco sender without the external resistor part #AC1513321 and it reads too low. So three sender's tried and the gauge still won't read correctly. If the gauge is calibrated to original GM specs, ONE of the sender's should have worked. Does anyone know of a sender and part # that will make this read 180*? Thanks PT
