70 Spark Plug Wire Bracket Finish - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    What finish should the bracket on the left side rear have form the factory?
    This is the bracket and the rubber grommet with all four wires passing through.
    NOS bracket is black. Should it be orange?
    Bill
    • 43258
    Re: 70 Spark Plug Wire Bracket Finish
    Bill
    Bill-----
    The left side lower plug wire support was painted semi-gloss black. None were engine orange since they were installed at St. Louis and not Flint.
    • Bill L.
      • February 1, 2004
      • 1403
      Thank you Joe.
      Bill
      • Mike E.
        • February 28, 1975
        • 5141
        You say left side rear--does that mean lower or upper? Attached to the intake manifold or to the block down near the bell housing? I just want to make sure we're giving you the right answer--the lower is black, the upper is orange.
        • Bill L.
          • February 1, 2004
          • 1403
          It is the lower.
          Thanks!
