Vacuum Advance Canister - NCRS Discussion Boards
  • Andrew P.
    • January 4, 2008
    • 36
    Hello,
    Anyone have any specs on Vacuum advance canister VC-1615? (1115360)
    Andrew
    • 43290
    Re: Vacuum Advance Canister
    Originally posted by Andrew Papanicolaou (48361)
    Hello,
    Andrew
    Andrew-----
    I can give you the specs on a GM #1115360. However, I do not show the VC-1615 as being a replacement for it. In fact, I can't find a VC-1615 at all. In any event, the GM #1115360 vacuum control is as follows:
    maximum crankshaft degrees of advance= 12 degrees @ 12 inches vacuum
    inches of vacuum to start plunger= 7 inches
    I show the following part numbers as being equivalent to the 1115360:
    NAPA/Echlin----VC1765SB
    Standard Motor Parts----VC24A
    Delco----D1383X
    New GM #-----19138049
    All of the above are stamped "B10"
