1957 Fuelie Tach Cable Help Needed - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    I have a friend who is putting a modern tach. drive distributor in his 57' and he needs to know what cable he needs to order in order to fit his center dash (stock location) mounted tach. Wouldn't this be the same cable that is used in a high-horse fuelie 57' except for the big brake cars? Where can I order this part for him?
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 1957 Fuelie Tach Cable Help Needed
    should be able to get what ya need at the local AC Delco distributor. measure the length ya need and try Delco.mike PS: doubt the tach's calibration (once you drive it off the distributor) will be identical to the generator driven tack cable.mike
