After having my car for 3 years or so now, I find that I am still not impressed with the stopping power of the car. I thought that it would stop better then it does. In fact, I think that my 2001 Explorer with 110k miles stops better.
Over the time I have had the car I have;
-Rebuilt each brake caliper. They were sleeved prior to my ownership so all I did was upgrade to O-ring seals in the pistons.
- Rebuilt the original master cylinder, followed by bench bleeding.
- Replaced the front crossover brake line.
- Replaced all of the rubber lines going to the calipers.
- drained the system and filled with new DOT3 fluid.
- Bleed the brakes numerous times by gravity and pedal pumping.
- New pads, VBP ferro carbon.
- New rear rotors, front rotors are the originals
- I have NOT done anything with the vacuum booster.
I have a firm pedal and the car tracks straight when stopping, I'm just not impressed with the stopping power. I was sort of expecting that eyeballs coming out of their sockets feeling when I stand on the brakes. Instead I get the "holy cow I should have started braking earlier" feeling.
Don't get me wrong, the car stops and I feel safe driving it, I just thought it would stop better. Am I expecting too much?
LS5, 4spd, power brakes
Tom
Tom
). When I had the car in for the annual safety inspection last spring, we gravity bleed them while it was up on the lift. Filled up about an inch of fluid from each caliper into a container. No difference noted.
