interior paint color - NCRS Discussion Boards
  • Peter F.
    • October 26, 2008
    • 2
    I have a 1960 with red interior and need to repaint some of interior console and kick plates. What is color and where can I find
  • Joe M.
    • April 30, 1990
    • 1338
    Re: interior paint color
    Corvette Central sells aerosol cans. Truck delivery only, no air freight.
    • Dick W.
      • 10483
      Your local automotive paint jobber should be able to mix the color for you. Some even will put it in aerosol cans.
      Dick Whittington
      • Joe M.
        • April 30, 1990
        • 1338
        The biggest problem I had with painting the interior pot metal parts on my 1960 was getting the paint to adhere. I stripped all of the old paint to bare metal, then sprayed a self-etching primer, then applied to color coat. Once the color coat dried, if I touched it, it would flake off. I went through the entire process on dash parts and end caps and had flaking at least two times; still don't know what the problem was.
        • Dick W.
          • 10483
          Problem with most aerosol self etching primers is that they do not bond as well as the materials available to the professional trade. Always scuff the bare metal before applying primer. If it is steel I like to use a etching wash just as good insurance.
          Dick Whittington
          • Jean C.
            • June 30, 2003
            • 688
            Joe,
            I had good luck using interior dye (paint?) when restoring the center console on my '64. Absolutely no flaking of the color coat. Matching colors; however, can be a pain in the you-know-what.
            Best regards,
            • Gary C.
              Administrator
              • October 1, 1982
              • 17771
              Peter, John Hinckley told us that Tower Paint http://www.towerpaint.com/ will mix any color in spray cans. Gary....
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • Mike M.
                Director Region V
                • August 31, 1994
                • 1463
                Always, use a good metal prep/de-greaser prior to priming and if sanded, after each sanding.
                HaND
