Frigidaire Foil Label Opinion - NCRS Discussion Boards
  • Joe G.
    • February 1, 2002
    • 89
    Hi all,
    I am having the internals of my compressor rebuilt. Attached is a photo of the label on the unit which I believe to be original to the car. Some of the reproduction labels appear to be a bit longer for the 740 model. With my usual restoration thought process of maintaining originality, I am trying to protect this one. I do not have an original one to compare with, hence my question.
    Does it look to be a correct size label?
    Code 042013
    late 71 BB
    Thanks Joe
  • Kenneth B.
    • August 31, 1984
    • 2091
    Re: Frigidaire Foil Label Opinion
    Originally posted by Joe Greer (37305)
    Hi all,
    Code 042013
    late 71 BB
    Thanks Joe
    JOE
    I looked at my 70 & it looks like yours. It is 4.0" long & the green part is .897. Good luck with the resto.
    KEN
      • 15640
      Does the code number work for your car? You know that is a date, right? Instructions on how to decode it are in the TIM&JG. I would do it for you, but I can't read all the numbers.
      I'm with Ken; it does look like an original label
      • Joe G.
        • February 1, 2002
        • 89
        Hi Terry,
        The way I understand the code 042013 is 04 (month) 20 (day) 1 (year) 3 (shift). That works with my car. The AC hasn't worked in a long time. I am just starting to go through the components.
        I needed to have a sanity check on the label. Thanks for the input.
        Joe
        • Joe G.
          • February 1, 2002
          • 89
          Hi Ken,
          Thanks for checking yours and the measurements.
          Joe
            • 15640
            Hi Terry,
            Joe
            Joe,
            The date code fitting the build of the car is the final proof of originality. Do your best to keep that label on the compressor. I doubt you would be pleased with one of the reproductions, unless their quality has changed lately.
