C-1 Rear license plate bracket spacer - NCRS Discussion Boards
  • Edward C.
    • August 31, 1993
    • 27
    Does any one have a good discription of an early 57 rear license plate bracket spacer?
  • Edward M.
    • November 1, 1985
    • 1916
    Re: C-1 Rear license plate bracket spacer
    Are you talking about the split washer / spacer that fits between the bracket and body on the bottom bolt? The one that has a letter or two (F or FW?) stamped on it?
    • Greg P.
      1961-62 Team Leader
      • March 1, 1985
      • 55
      The spacer is tapperd to the body and straight on the bracket side
      • Edward C.
        • August 31, 1993
        • 27
        It is the bottom spacer but I need to know the material it is made of and the dimensions. Thanks
        • Edward C.
          • August 31, 1993
          • 27
          Is is rubber and what are the dimensions?
          • Doug F.
            • November 1, 1983
            • 322
            7/16" od with split, 1/4" tall, not the greatest design of all time but it sorta works, i hope i.ve attached a photo of an original http://members.cox.net/cfaber/pics/IMG_2875.JPG
