54 hard steering - NCRS Discussion Boards
54 hard steering
  • Brad H.
    • August 12, 2007
    • 724
    54 hard steering
    As noted before had hard steering or lumpy feel when turning, raised front off ground turning wheels by hand definate stop points adjusted small nut and screw back one turn at steering wheel is now pretty smooth but still a little lumpy when turning at the tires, am I ok what would the drag link do if it were bad and how to check? Thank you Brad
  • Jim L.
    • September 30, 1979
    • 1817
    Re: 54 hard steering
    I'd bet money the lumpy steering you feel is due to a pit or maybe even a dent in the sector roller in the steering box. This is a common problem with the early cars and no adjustment in the world is going to make that go away. You'll need to rebuild the box.
    Jim
    • Roy B.
      • February 1, 1975
      • 7044
      Check to see if parts are worn and adjusted correct.
      • Bill M.
        • April 1, 1977
        • 1386
        I had the lumpy feel in my '59. Had to rebuild the steering box.
        • Michael L.
          • July 31, 2005
          • 562
          When I rebuilt my car, all was well with pitman arm and drag link, it was a chip on the worm gear that caused my steering bind. I rebuilt my drag link while I was rebuilding front suspension, but that just needed cleaning and fresh grease.The rebuild of the box was $500 to do myself, but money well spent. Steers beautifully now.
          • Joe R.
            • July 31, 1994
            • 287
            Brad, ditto on the rebuild. I tried to repair the sector roller and shaft assy to no avail. I invested in the kit from Corvette Steering and rebuilt it. It now works perfectly.
            Joe
            • Brad H.
              • August 12, 2007
              • 724
              Thank you all for your input, I will see If my adjustments have made a diff. when rain stops on the road and go from there. Brad.
