Does anyone know where I can buy the contact that mates with the parking brake warning light switch on a 66? It goes on the end of a brown wire that comes from the warning light. I have the wire but no contact, and I can't find a source. It looks like some sort of male bullet contact.Thanks for any help.
66 Parking Brake Warning Light switch contact
Tags: None
Re: 66 Parking Brake Warning Light switch contact
OK now that I actually read your post. If you just need the contact for the end of the wire you can see the original with its plastic sleeve below. The contact with the wire is a M&H repo harness. It appears a 3/16 plug should work which would be available at radio shack.
Thank you Greg. I'll go to radio Shack for the connector. Thanks again for your help. Bill Gould- Top
