I am looking for an original jack for my 65 vin #113429. After reading the jg am I correct in saying that I should find one with the sealed bearing behing the 3/4 nut? Thanks
65 Jack Question
Tags: None
- Top
Re: 65 Jack Question
Raymond,
I believe that is correct. I think you should be looking for a type 2 as earlier 65's used the first design. I may be wrong but the difference is reinforcing on the lift arms and the nut (where the screw threads) is welded to the other side of the bracket. Someone will correct me if I have it wrong.
- Top
