Convertible top protection when folded - NCRS Discussion Boards
  • Troy P.
    • January 31, 1989
    • 1279
    On the 54 there is a rectangular beige soft pad on the cover for the gas tank. Also there are two sort of bone/pork chop shaped pads that go on the underside of the deck lid. What is the correct color of these for the 54? Black or beige? I seem to think mine were beige but that was 15 years ago and I can't recall. I bought two repos recently and was told that they only came black.
    Also, does anyone have a photo that shows the exact position and orientation of these pads on the lid that they could share? I knew this was going to be tricky so I took a picture before I removed the originals. However, I have misplaced the photo.
  • Roy B.
    • January 31, 1975
    • 7044
    Re: Convertible top protection when folded
    They're wrong beige pad was used on many 54's depending on the color, 55 all but white used beige I believe, along with the top hold down straps also being beige if the pads are
    • Troy P.
      • January 31, 1989
      • 1279
      Thanks Roy. Very interesting about the footmans straps. I thought they were always black. Obviously not by the photos you sent.
      BTW interesting green color on the car. Very strange.
      • Roy B.
        • January 31, 1975
        • 7044
        You cant always go by the JM or suppliers if you wont your Corvette right and original , but if your going for top flight then follow the JM right or wrong.
