Re: New 1967-68 Standard Strg Column Paper
Jim,
The colors that you show are the chassis harness colors.
However, even my original switch has striped wires in the switch harness that are somewhat consistent with the chassis harness. The replacement switch also may have different stripe or solid colors.
The plastic connector has no alpha markings as to where the colored or striped wires are positioned in the connector. So when you remove the pins from the connector, sketch the positions or take a photo. I always make sure I take some closeup pickups whenever I disassemble something for the first time.
Actually, it is pretty easy to reassemble the wires on the connector, as the wires are in the correct order in molded portion of the harness up from the connector, you just have to remember which end to start with.
The white stripe wire (or white wire) from the switch is always on the end position, and would match the white wire (Brake Light) from the chassis harness. Here's my replacement switch harness on the original black connector (the replacement came with an incorrect brown connector, we can't have that
Jim, if you have a drawing of the internal wiring of the switch, I'd like to get a copy. I was planning on doing an electrical schematic to show how it works. Interesting switch which controls 4 circuits.
Jerry Fuccillo
gjfeng@sbcglobal.net
Jim,
Jerry Fuccillo
