1970 U-joints - NCRS Discussion Boards
1970 U-joints
  • Stephen B.
    • April 1, 1988
    • 876
    1970 U-joints
    Does anyone have pictures of original u-joints for a 1970?
  • Mark D.
    1984-96 Team Leader
    • June 30, 1988
    • 2157
    Re: 1970 U-joints
    Driveshaft:
    Halfshaft:
    Kramden
    • Stephen B.
      • April 1, 1988
      • 876
      Re: 1970 U-joints
      Thanks. Isn't the end cap suppose to say "Spicer" on it?
        • 3416
        Re: 1970 U-joints
        Hi Stephen,
        For frame of reference only; my 71, #6589, January built, SB, has SPICER written on the end of the cap with the letters in an arc. They are the original u-joints.
        PS: I hit enter too soon.
        The above is for the DRIVE-SHAFT u-joints. The HALF-SHAFT u-joint caps are plain/smooth on the end.
        • Stephen B.
          • April 1, 1988
          • 876
          Re: 1970 U-joints
          Thanks Alan. I'd love to see the "Spicer" on the u-joints if you or someone has a picture.
            • 43248
            Re: 1970 U-joints
            Stephen-----
            I don't think that all u-joints used on Corvettes of the period did have the "Spicer" brand name embossed on the caps. I believe that some were either manufactured by Spicer with NO reference to Spicer on the joint AND with "GM" embossed on the body of the joint OR they were manufactured by some internal GM division. Personally, I think it was the latter. This applied mainly to the half-shaft u-joints, but I believe it included driveshaft u-joints, as well.
            • Greg L.
              • March 1, 2006
              • 2291
              Re: 1970 U-joints
              Here are some joints out of my 69. The restored joint used to look like the old cruddy one on the left. It's amazing what one can do with a mild solution of muriatic acid, a stainless steel brush and some patients.
              If you would like full size pics just send me your e-mail and I'll send you some.
                • 11669
                Re: 1970 U-joints
                Were the bearings inside the U-joints still good?
                "Most" old ones I've seen have turned to rust powder and are useless.
                Patrick
                • Greg L.
                  • March 1, 2006
                  • 2291
                  Re: 1970 U-joints
                  Yes Patrick they were almost like new. You could see where the needles had started to polish little marks on the stubs but there was no measurable wear what so ever.
                  • Stephen B.
                    • April 1, 1988
                    • 876
                    Re: 1970 U-joints
                    Greg,
                    Please send me the pictures to BunkyByrd@aol.com. I appreciate it.
                    Joe,
                    The 70-72 judging manual states that the half shaft joints had Spicer on the caps, but it does not say with regard to the driveshaft. I was curious to see what a Spicer stamped cap looked like.
                    • Mark D.
                      1984-96 Team Leader
                      • June 30, 1988
                      • 2157
                      Re: 1970 U-joints
                      Here is a shot of some GM part numbers
                      Kramden
                      • Stephen B.
                        • April 1, 1988
                        • 876
                        Re: 1970 U-joints
                        Thanks for the pic.
                          • 43248
                          Re: 1970 U-joints
                          Greg------
                          These look like 68-70 THM-400 driveshaft u-joints. Is that what they are?
                          • Greg L.
                            • March 1, 2006
                            • 2291
                            Re: 1970 U-joints
                            That's what they are Joe...
                            What is it about them that tells you that???
                              • 43248
                              Re: 1970 U-joints
                              Greg-----
                              Several things. The apparent size of the bearing caps, the apparent width of the fingers, the "depressions" in the center of the body of the joint, and the fact that they have "Spicer" on the end caps.
