67 Tailight Harness - NCRS Discussion Boards
67 Tailight Harness
  • Mike P.
    • May 31, 1992
    • 25
    67 Tailight Harness
    Hello does anyone out there have any photos or info of rear tailight,fuel send unit wiring routing,clamping, and fuel hose overflow routing clamping ? Do the tailight ground wires go on the top tailight housing studs or the bottom studs, and is there any particular direction of terminal end of ground wires where it attaches to studs ? Thanks Mike
    Re: 67 Tailight Harness
    Mike -
    The ground terminals go on the top studs, and the harness routes across the panel above the taillights. The overflow hose just routes straight down into the bottom of the RH bumper vertical, retained to the brace rod with a tie strap.
    • Mike P.
      • May 31, 1992
      • 25
      do you know anything about three clamps and their attaching point that hold harness in place ? Mike
      • Stephen L.
        • May 31, 1984
        • 3162
        The connections clamps etc are shown in your AIM.
