Pertronix vs Points - NCRS Discussion Boards
Pertronix vs Points
  • Tom D.
    • April 1, 2008
    • 9
    Pertronix vs Points
    Does anyone know what kind of point deduction I could expect if I use Pertronix ignition rather than points on a 67 L79. I have the correct distributor, cap, Coil,and vacume advance on the car. As far as I know the only visual difference are the wires to the coil. Thanks.
  • Donald T.
    • September 30, 2002
    • 1319
    Re: Pertronix vs Points
    Breakerless SE will give you a hidden electronic ignition without the extra wire. So it might receive less of a deduction. However, as easy as it is to just replace it with points, why not just use points for judging and avoid the deduction?
      The line item for "distributor, cap, and vacuum advance" is allocated 15 originality points. Presence of a Pertronix unit instead of breaker points means that the points are "missing"; I'd probably take two points for distributor configuration and completeness, others may differ.
      • Arland D.
        Moderator
        • July 31, 1980
        • 424
        Tom,
        Driving our 67 to the national several years ago with a Pertronix breakerless ignition inside the completely stock distributor resulted in no deduction (as I recall). The internal points aren't present but they also aren't visible and the only external evidence was the additional brown wire which the judges did ask about. Results may vary from year to year and meet to meet but it isn't a significant deduction. Installing the breakerless ignition was a worthwhile change for driveability - just one opinion.
        Arland
        • Stuart F.
          • August 31, 1996
          • 4676
          Arland;
          I second the opinion on the Pertronix. I use the II with the 12 volt input so I try to hide a jumper wire around the back of my ballast resistor. It is a black wire and is seldom noticed. Sure don't miss having to change plugs every time I get held up in a little in town traffic. It will pull red line every time right out of town.
          Stu Fox
          • John D.
            • June 30, 1991
            • 875
            Some snooping judges have been known to peek under the adjustment window in the distributor cap.....sealing the window shut with a bit of glue solves the problem.
            • Brian M.
              • February 1, 1997
              • 1840
              I've done just that.
