C2 Motor Mounts - NCRS Discussion Boards
C2 Motor Mounts
  • Dave G.
    • February 21, 2007
    • 14
    C2 Motor Mounts
    Some one used a cutting torch on my motor mounts, is there a manufacture that reproduces them?
  • Tim S.
    • May 31, 1990
    • 711
    Re: C2 Motor Mounts
    Are you refering to the frame horns?
    • Dave G.
      • February 21, 2007
      • 14
      Re: C2 Motor Mounts
      I did not know the correct term, but yes it is the portion of the motor mounts that is welded to the frame. Some one used a cutting torch to remove the bolts at one point, the car was stolen once.
      I need to replace or repair the frame horns if that is what they are called.
      Thanks for your help on this.
        • 43246
        Re: C2 Motor Mounts
        Dave-----
        I would check with Vette Products of Michigan (www.vetteproducts.com). I'm almost certain that they reproduce the parts you need.
