69 Smog Pump Diverter Valve - NCRS Discussion Boards
  • Anthony P.
    • April 1, 2005
    • 42
    Hi.
    I have a question regarding the diverter valve part number on my 69 350, - 350hp.
    The NCRS manual says that the part # should be on the flat side of the valve bellow the muffler.
    Mine has no number bellow the muffler but has 7034481 on the neck where the 2 hoses attach. The box that the valve came in has the correct part# on it (7029199).
    So is the 7034481 a casting # ??? and if it is should it have the GM number bellow the muffler or is this valve incorrect for my application?
    Anthony
  • Grant W.
    • December 1, 1987
    • 407
    Re: 69 Smog Pump Diverter Valve
    Hi Anthony
    Flip your diverter and read inbetween the mounting holes as pictured. 69 small block is 29199 with GL black ink on the round dome end. As pictured is a 68 427, 69 427L88
    Thanks, Grant
    • Anthony P.
      • April 1, 2005
      • 42
      Grant,
      Thanks for the information. Just went in the garage found the # it's very hard to see.
      Thanks again
      Anthony
        • 43219
        Originally posted by Anthony Paxinopoulos (43618)
        Hi.
        Anthony
        Anthony----
        7034481 is the casting number for the COMPONENT of the valve on which it is embossed. The same component is found on other diverter valves and, consequently, does not identify any particular valve.
        • Anthony P.
          • April 1, 2005
          • 42
          Anthony----
          Thanks Joe for that information.
          Anthony
