67 instrument cluster two-letter code - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5137
    Does anyone know offhand the two-letter instrument cluster codes that are on the sticker on the back of the cluster?
    I have an original (documented by tank sticker) 300hp car with speedminder. I sent it out to have the instruments redone, and I think the restorer that did it simply put a standard tag on it and removed my original tag. I was too dumb to register the two letters before sending it out.
    Are they all white with green lettering?
  • Philip C.
    • December 1, 1984
    • 1117
    Re: 67 instrument cluster two-letter code
    Hi Mike sorry I cant find my notes for the letters but I know theres an early and late on the 300 W/speedmind. Phil 8063
      Mike -
      My base (non-speed warning) '67 300hp cluster has a red on white "LA" sticker; Brian Tilles (Corvette Specialties of Maryland) and the other cluster rebuilders have the codes for each combination.
      • Rick S.
        • January 1, 2003
        • 1203
        My 67 350HP car has LC, red letters on white sticker.
        Rick
        • Ray G.
          • May 31, 1986
          • 1189
          Hello Mike Ernst;
          Here my '67 390 Corvette. w/ speedminder, but not on the tank sheet.
          Hope this helps.
          Ray
          I hope you dance
          • Brian T.
            • September 30, 1990
            • 190
            All of the speed warning labels were white with green letters. Non speed warning were as pictured above.
            • Joe R.
              • July 31, 1976
              • 4550
              Mike,
              For someone with a number lower than mine, I can cough up a green tag for you.
              I have an original green tag (speedminder) with LB. It originally had a white sticker over the LB as LB is the designation for SHP. Yours originally was an LA designation.
              It was quite common for the green stickers to have a white sticker over the HP designation. This is only common with speedminders. I'm sure it was cause they run out of green stickers for the lower HP and I don't recall ever seeing a cluster with speedminder and SHP. Probably made them but I don't ever recall seeing one! Maybe reserved for those rare L-88's. Yeah right!
              Just e-mail me and I'll drop it in an envelope to you. Or you can pick it up at the NCRS Regional at Old Town.
              JR
