weatherstrip oem look - NCRS Discussion Boards
  • Craig O.
    • July 31, 1983
    • 207
    is there a product to simulate the weatherstrip glue amber look that is smeared around doors and hood area weatherstripping, black and yellow seem to be the only choice. or does someone have a clever method to achieve that aged look?
  • Dick W.
    • 10483
    Re: weatherstrip oem look
    Go to your local Lowe's and get a small can of contact cement. Go to a local auto parts and get an acid brush. Brush the contact cement on the body and the w/s. Allow to tack and them put together. Looks very original
    Dick Whittington
    • Arnold P.
      • August 31, 2005
      • 48
      hi,craig, i used 3m weather strip adhesive on my car. it's the yellow type. it's commonly called "gorrilla snot" if you use it you'll know why. pappy
      • Dick W.
        • 10483
        The 3M is a brighter yellow color that the original. That is the reason I like the contact cement, the color is very close to the original
        Dick Whittington
          • 11698
          Originally posted by Lyndon Sharpton (12791)
          I used the 3M sure it is brighter but I would bet that when the cars were new so was the color brighter and only lightened with age.
          Actually that is backwards.
          It started out nearly clear, and yellowed with age.
          No matter what, the bright yellow stuff available from 3M is not the correct shade for our vintage Corvettes.
