Wire I.D. - NCRS Discussion Boards
Wire I.D.
  • Dan L.
    • November 10, 2008
    • 81
    Wire I.D.
    Can anyone I.D. this? I found it hanging near the driver side head light bucket. 3 wire, blk, brn, grn....
    '70, Conv. 350/350 W/AC
    DAN
  • William C.
    • May 31, 1975
    • 6037
    Re: Wire I.D.
    High beam headlamp connector with fiberoptic, the two "tabs" were the terminals on the back of a sealed beam headlamp.
    Bill Clupper #618
    • Michael W.
      • April 1, 1997
      • 4290
      Re: Wire I.D.
      Those two tabs are also 'live' with 12 VDC when the headlights are on, best remove them from the connector.
      • Dan L.
        • November 10, 2008
        • 81
        Re: Wire I.D.
        Thanks for the info Bill and Mike. Car has no battery power at the moment but this connector will be put in its proper location before we give her juice....
        DAN
          • 3415
          Re: Wire I.D.
          I had one of those 'tabs' pull loose from an original headlight on my 71. I was able to solder it back into place and the headlight still lives. Maybe you can give yours a try if it's an original!
          • Dan L.
            • November 10, 2008
            • 81
            Re: Wire I.D.
            We'll give it a try. Thanks..
            DAN
