Re: '67 L-79 Holley Questions...
Bob,
I guess you would call them the shaft seals. On my 751 3810, I found the seals to be just heavy clear tape wrapped around the shaft, 2 places on the primary shaft and 4 places on the secondary shaft. I'm told that they were teflon impregnated.
I have obtained a set of replacements and they appear to be white strips of plastic, flexible but more rigid than the tape on the original.
Have also obtained a new replacement primary throttle shaft for a 3810 (as the original had a bunged up throttle lever). This has a different setup for the seals, and looks like it is set up for 3 O-rings on each side of shaft at the bearing surfaces.
So I'm still scratching my head on assembling the original throttle body base, while the replacement throttle body is on the car and working fine.
Let me know what you find when you pull the shafts.
Bob,
