Re: BB - Replace high pressure oil pump?
Joe-----
It depends what your priorities are. If it's exactly correct configuration, then you need to use a "4 piece" gasket set, as-original, with steel-reinforced, cork rail gaskets and rubber end seals.
If you want the best sealing, then use a 1 piece, neoprene type gasket of Fel-Pro #OS-30061T or equivalent.
Joe-----
