C-2 antenna ground plate ? - NCRS Discussion Boards
  • Louie C.
    • March 1, 1980
    • 43
    Through the years, in buying parts for my 67, I still don't know if I have found the correct antenna ground plate. Is there a difference in the 63 to 67? What identifying things should I be looking for to ensure having the correct one?
    Lou
  • Timothy B.
    • April 30, 1983
    • 5183
    Re: C-2 antenna ground plate ?
    Lou,
    I can only tell you the early 63's used a small ground plate that looks like the center section for the larger piece used for AM/FM radio 63-67, (it probably is the center section). I believe the change to FM radio is when the plate changed.
    I can get you a picture of the plate on my 67 (never been removed) but you will need to wait a few days as the car is not in my garage, it's on vacation at the moment.
