Exhaust pipe rust prevention? - NCRS Discussion Boards
  • Larry C.
    • April 1, 1980
    • 279
    Any thoughts/suggestions on preventing surface rust on ordinary carbon steel exhaust pipe tubing? Factory coating of the C-1 exhaust system burned off pretty quickly I would assume. Will 1200 degree black paint hold up for any length of time?
    Acquired NOS exhaust pipes for C-1 and would like to keep them looking like new as long as possible. May not be possible, I guess, short of having the exhaust aluminized.
  • Bill M.
    • April 1, 1977
    • 1386
    Re: Exhaust pipe rust prevention?
    I painted the plain carbon steel part of my sidepipes 30 years ago with high-temp black paint. They still look OK. Can't say the same for the cast iron manifolds painted with the same stuff. They've gotten rusty.
    • Larry C.
      • April 1, 1980
      • 279
      Bill,
      Thanks, you confirmed where I was leaning on using the high-temp black paint.
      • Bob S.
        • January 1, 2004
        • 182
        Has anyone tried a ceramic coating?? I Googled "ceramic coating colors" and came up with a source claiming to provide a "cast iron gray finish". It may be overkill, but that seems like a viable option, although I don't know how it would fare in judging.....
        Bob
        • Gary B.
          • September 30, 1987
          • 305
          I brushed my Exhaust manifolds with a product by "NYBCO" called NEUTRA RUST . It is a watery white liquid. It was distributed by "Bernard Marks Company" in Toronto. I think I originally got it at a Home Hardware.
          It gave a natural finish that has lasted about 15 years.
          If anyone finds this product please let me know as I would like to buy some more.
          Here is the only link I found. http://www.neutrarustuk.com/10325/info.php?p=2&pno=0
          • Paul J.
            • September 9, 2008
            • 2091
            Larry:
            Bob has a good idea. A couple of years ago I worked with a company called High Performance Coatings, who coat exhaust systems and metal parts for trucks, race cars, and show cars. I think that it's a ceramic coating but I'm not sure. They're very confident about thier product but I think that it's also expensive. They have locations in Utah, Arizona, Oklahoma, and Greensboro, North Carolina.
            www.hpcoatings.com
            I know that there are also other coating companies out there like AMR but I'm not as familiar with them.
            Paul
            • Joe T.
              • June 3, 2008
              • 7
              I've had good luck with VHT Satin Clear "Flameproof" paint.
              It is designed for header applications. The manufacturer recommends a curing process that includes at least two "cure" cycles that require maintaining operating temperatures for a period of time and allowing complete cool-down between cure cycles.
              Don't apply it too heavily; it will discolor/yellow if it's too thick.
              I've used it with good success on exhaust weld joints and to protect NOS pipes.
              Edit: I forgot to mention, it is also available in black and other colors.
