63 Gas Pedal - NCRS Discussion Boards
63 Gas Pedal
  • Jeffrey A.
    • October 22, 2006
    • 273
    63 Gas Pedal
    Does anyone have a picture of a correct gas pedal for a 63they could post for me to look at. The judging manaul is not very clear on this from I can see. My car currently has a replacement one that is not correct for 63. Any help would be appreciated.
    Re: 63 Gas Pedal
    Jeffrey -
    As the JG states, the two outboard grooves on the original pedal were squared-off at the top, just like the rest of the grooves; the reproductions have a slight angle at the top of the two outboard grooves.
    The JG also states that the two attaching screws are phosphated, which is incorrect - they were zincad.
    • Jeffrey A.
      • October 22, 2006
      • 273
      Re: 63 Gas Pedal
      John
      thank you very much
      Jeff
      • Jeffrey A.
        • October 22, 2006
        • 273
        Re: 63 Gas Pedal
        John, at the outter edge of the pedal do you know if it is squared off as well or is it rounded.
        • Alan D.
          • January 1, 2005
          • 2046
          Re: 63 Gas Pedal
          Well here is a 64 pedal. shows the area under discussion. You will need somebody to confirm if the 63 & 64 are the same, I do not know.
          • Jeffrey A.
            • October 22, 2006
            • 273
            Re: 63 Gas Pedal
            Great. That like just like the one on my car
            thank you
            • Douglas C.
              • September 30, 1988
              • 237
              Re: 63 Gas Pedal
              There's currently an "NOS" C2 gas pedal on ebay, but this is a replacement and doesn't look anything at all like the originals.
              They show up quite frequently on ebay, but should be called NORS , definitely not NOS.
              • Jeffrey A.
                • October 22, 2006
                • 273
                Re: 63 Gas Pedal
                You are correct. Its amazing what some people try to pull off
