62 hardtop latches - NCRS Discussion Boards
62 hardtop latches
  • Houston U.
    • June 30, 2000
    • 75
    62 hardtop latches
    Can the latches on an original 62 hardtop be adjusted for tightness?
  • Mike E.
    • February 28, 1975
    • 5140
    Re: 62 hardtop latches
    Yes--loosen both screws enough, and the whole latch will move up and down underneath the outside chrome plate. Then tighten when you think you've moved the latch up enough. Try the fit, and if necessary, adjust again.
    • Houston U.
      • June 30, 2000
      • 75
      Mike, thank you, I'll try it.
