67 Rag joint assembly question - NCRS Discussion Boards
  • Don M.
    • June 30, 1998
    • 155
    At a recent event, I had a deduction under Coupler(rag joint) assembly, it said missing black plastic insulators. I went to my trusty Long Island Corvette catalogue and ordered a pair of coupler pin bumpers. I assummed that was what I was missing. Well, when I got them in the mail, I already had installed those pin bumpers a couple of years ago. What in the world am I missing then??? I'm puzzled.
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: 67 Rag joint assembly question
    I would recommend that you contact the National Team Leader and/or refer to the Judges, names will be on your judging sheets.
    HaND
    • Joel F.
      • April 30, 2004
      • 659
      Here is a picture of a rag joint from a 67 Duntov
      • Joel F.
        • April 30, 2004
        • 659
        let's try this again . . .
        • Rick S.
          • January 1, 2003
          • 1203
          Here is my 67, I have no idea if it is correct, totally wrong or somewhere in between.
          • Don M.
            • June 30, 1998
            • 155
            Thanks so much for the photo!
              Rick -
              Your black plastic insulators over the safety pins are missing too; see the photo in Joel's second post.
              • Stephen L.
                • May 31, 1984
                • 3159
                Photo of rag joint insulator. About the size of a quarter and installed on the stud.
                • Rick S.
                  • January 1, 2003
                  • 1203
                  Thanks John and Stephen for your close up photo.
                  Rick
                  • Jim S.
                    • August 31, 2001
                    • 730
                    I took over responsibility for the flexible coupling assembly at Saginaw Steering Gear around 1970. I am sure that the rubber insulator was not in production at that time. I have seen them on first generation early Camaro flex couplings but I was not aware that they were on 1967 Vette as well. Your photo shows the part number 7800470 very clearly. I will see if my contact at Saginaw can get me information on its useage and what years.
                    Jim
