'61 Ignition Shielding - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    I am having a fit trying to get some new ignition shielding on my '61. It was a new set from Paragon. The part I am having a problem with is the right hand vertical shield. When I get it over the spark plug wire bracket on the draft tube, it is too short to go up inside the Distributor top shield, and the bottom it is too far below the hole in the Lower horizontal shield. If I pull it up to connect the bottom in Lower shield, there is about 6" of spark plug wires showing. On top of all that I can't get the hole in the vertical shield to align with the nut on the back of the distributor shield. Is the vertical shield supposed to go up inside the Distributor shield? Any suggestions?
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: '61 Ignition Shielding
    Could be the wrong road draft tube or maybe the sheilding is not correct. Ask someone to measure a known original part for you.
    • Richard P.
      • July 31, 2001
      • 173
      Anyone out there who could measure and/or take photo?
      • Ray C.
        • June 30, 2001
        • 1132
        Email me exactly what you are looking for, I have a very original 61 270 HP and a 1961 FI project car. I should be able to help!
        ray63@rochester.rr.com
        Ray Carney
        1961 Sateen Silver 270-HP
        1961 Fawn Beige 315-HP
