Engine pad preservation - NCRS Discussion Boards
  • Thomas H.
    • August 31, 2005
    • 1057
    I was just looking around my engine compartment today and noticed that my number pad has developed a pretty good case of surface rust. What is the best way to clean the surface rust from the pad and what should I put on it to protect it?
    Tom
    2007 Z06, Lemans Blue
    • 11643
    Re: Engine pad preservation
    I just use some PreLube 6 on mine.
    It works great to protect it, and usually will wipe off the minor surface rust that accumulates on pads.
    Patrick
      Try some Naval Gel and a toothbrush. Do NOT use an abrasive tool as there's a good possibility you'll 'distrub' the factory original broach marks by 'sawing' back and forth as you attempt to clean the rust!
      • Thomas H.
        • August 31, 2005
        • 1057
        Thanks Pat, Jack.
        When I rebuilt the engine, the pad was clean and the broach marks crisp. I had been putting some WD40 on it, but I suppose it wore off and I didn't keep up with it so I now have a good case of surface rust.
        I will go with the naval jelly (toothbrush?) and follow up with the prelube 6 and see how we fair this winter. My garage goes through some cold/damp cycles in the fall/spring that contribute to the moisture build up on everything.
        Tom
        • Jay G.
          • August 31, 1993
          • 398
          When pad is clean. Take sm amt of oil 10/30 etc and apply to finish pad. Sould keep it from further rust accumlation.
          • John D.
            • June 30, 1991
            • 875
            I use a healthy coating of wheel bearing grease on it........
            • Paul J.
              • September 9, 2008
              • 2091
              Tom:
              All of the previous suggestions work quite well, as I can say from experience, but all of them require periodic re-coating. The best low maintenance solution is a light coat of high temp paint. You can get this in a medium gloss clear, if you wish.
              Paul
              • Ian G.
                • September 3, 2007
                • 1114
                That would be a good permanent solution; problem is you'd have to remove the paint with laquer thinner for judging, and aren't C2's supposed to have paint in the recesses of the numbers? I know C1s should have no paint on the pad at all...
                • Joel T.
                  • April 30, 2005
                  • 765
                  Hi Guys;
                  Good topic and a good thread to which I am going to add a dumb question.... For judging purposes, is it not a good idea to have some surface rust/dirt/grease on the pad? The reason I ask is that the pad on my car has been kept clean but at a recent judging event I got whacked like 65 points on "originality"... the judge said the pad was "too shiny"...
                  Joel
                  • Ray C.
                    • June 30, 2001
                    • 1132
                    A old-timer (and I am 59) told me that every time you check the oil, wipe the oil from the rag/papper towel on to the pad. You shoud never have a rust problem.
                    Ray
                    Ray Carney
                    1961 Sateen Silver 270-HP
                    1961 Fawn Beige 315-HP
                      Originally posted by Joel Talka (43778)
                      Hi Guys;
                      Joel
                      Strange deduction - each of the stamps is 25 points and the surface is 38, and it's supposed to look like it did when it was new.....
                      • Thomas H.
                        • August 31, 2005
                        • 1057
                        Originally posted by Paul Jordan (49474)
                        Tom:
                        Paul
                        Hmmmmmmmm, I like this idea. I don't forsee having the car judged anytime soon.
                        I wrestle with getting it judged. I know the paint is not in the best of shape and there are a few minor things that need attention before going through judging. I'd like to do it to get a basline of what I actually have though.
                        The way I'm thinking at the moment is that once it is judged, I'll have a list of "to do's" that would gnaw at me until I do them. As it stands right now, the only list I have for the car is:
                        Remove cover,
                        Get in,
                        Start,
                        Drive,
                        Return home
                        Shut off
                        Re-cover (after a cool down)
                        Pretty simple.................. for now
                        Tom
                        • Gerard Q.
                          • February 1, 2000
                          • 284
                          Patrick
                          I'm also a fan of Prelube 6
                          • R N.
                            • May 31, 2002
                            • 640
                            For protecting I use Boeshield T9 Aerosol.
