What have you found to be the best sequence to reinstall the WHOLE dash?
I know the pass side with map pocket should go in last and that the dash pad goes in first but I can't remember if the center gauge panel is assembled to the console and then they are install together OR if the drivers speedo/tach cluster should go in before or after the center gauge cluster???
The only way I have even been able to do this is by sliding the center gauge cluster and shifter console back as an assembly and only then can I get at those two nuts. The procedure in the manual sounds good on paper but doesn't work in real life...
