seat won't stay in place - NCRS Discussion Boards
  • Gary J.
    • April 3, 2008
    • 164
    I am have trouble with my seat staying "locked" in any position using the ajustment knob under the seat. It will continue to side forward or backward and not "lock" in place. If I hold the knob and arm at a certain angle/position it will "lock" but when I let go, the seat sides again in the forward or rearward direction. Any help or tips would be appreciated. Thanks Gary
    New England Chapter NCRS
  • Bill I.
    • January 29, 2008
    • 554
    Re: seat won't stay in place
    Gary, sounds like a spring is broke. Be VERY careful driving it. In fact, if I were you, I would not drive till fixed. Bill.
    • Stuart F.
      • August 31, 1996
      • 4676
      I have had a similar problem with my 63, only it just won't stay locked going backward in the last position which is where I've always had it. However, it won't come forward, rather if it don't lock it remains loose between the last notch and a full rear position. I have used a 2"x4" behind the seat for years to keep it in the last notch. I tell people that's just an emergency wheel chock I store back there.
      Stu Fox
      • Stewart A.
        • April 16, 2008
        • 1035
        Stu put a C1 seat in it they are way more cummfy !!!!!!
        Actually you should buy a C1.
        • Stuart F.
          • August 31, 1996
          • 4676
          Well, that's what I get for keeping the seat in only one position. I should have known that over time with all those "G" forces and my chubby posterior, something has to give. Got to get me one of those NASCAR racing seats I guess.
          Stu Fox
          • Gary J.
            • April 3, 2008
            • 164
            Bill:
            Thanks for the idea of the spring but it checked out fine, it appears that the attachment pin for the seat adjustment arm to the seat rail has too much play. The play allows for the arm to flex too much and not retain the position in the rail that you select. I am going to working to secure the pin more tightly and I believe that will solve the problem. Stu & Stew, keep your 2"X4" but I appreciate your vast technical knowledge.
            • Michael M.
              • February 1, 1993
              • 606
              The metal wire that goes between the two adjusting arms under the seat has to be longated so it will force the the latch down into the slot.
